Hi All.
I have a 14 plate 1.0ltr Corsa (petrol) on 64k miles.
The car starts and runs fine for approx 20 mins then loses power which gets progressively worse until it stops, it will not restart unless its left for about 15 mins then it starts and runs.
Went to a local garage and although no fault codes were found they suggested to replace the plugs and coil pack, which they did.
the problem still persists, took it to a second garage again and Still no fault codes found.
The car has had the fuel pump relay replaced, new battery, new fuel pump but has not cured the issue.
Any ideas ?
Any ideas ?
