Where can I get a replacement key fob from as mine has come apart & key keeps dropping in the ignition barrel. I've tried getting another case but the key won't flip as it's slightly different inside? Thanks.
I think you can push a pin through to release the blade, then just swap the blade over to the new fob - they don't flip well unless you use the 'flip' bit from the new fob.
