Good evening.
What is the limit on a leak off test to determine if the injector(s) needs replacing.
Corsa D 1.7 CDTi (A17DTS)
I've done a test with engine at operating temp, sat on idle for 3 mins and the results were:-
Cylinder 1 - 30ml
Cylinder 2 - 35ml
Cylinder 3 - 40ml
Cylinder 4 - 42ml
I did see online that a diesel specialist has said that anything over 30ml doing the same as I did is a dud injector, but as the amounts are quite close is it just normal for my injectors or are they all shagged?
Cylinder 1 - 30ml
Cylinder 2 - 35ml
Cylinder 3 - 40ml
Cylinder 4 - 42ml
