Hi guys, recently ive purchased some 2xcite headlights for my corsa D. The ones with a lightbar, and LEDs. After plugging them in and turning the engine on. The LEDs are very bright and look great, but the lightbar is very dim compared to how it looks on other peoples.
when i turn the sidelight setting on, the LEDs go dimmer, (as they should) but the lightbar stays the same, then when going back to “off” (1st setting on the lights, 2nd being sidelights 3rd being dipped) the lightbar flashes quickly as if trying to go brighter then wont. The LEDs go back to the daylight running brightness and look great.
20687
as you can see on the image the LEDs are bright snd look great, but the lightbar is pretty much off
this is how they should look!
20689
The only thing I can suggest is swap the wiring over so the light bar becomes the sidelight and the led becomes the running lights, it’s either that or the light bar themselves are faulty.
