Hey guys have a 63 plate limited edition corsa D.
My friends car handbrake as excessive play when pulling it up. I have tightened it down via the nut underneath the handbrake leather cover but it does not seem to really change anything and seems to be screwed down to its maximum already?
Is there anything else I need to be doing. Also does anyone know if this is an MOT fail. As it does hold the car but the handbrake is pulled up quite high?
Also is there anything else I should be looking at or inspecting just in case?
Any help be great
If it holds the car
I think if the level is near the end of its travel (i.e. pulling it all the way up) its a fail.
I wonder if the brake shoes are near the end of their life...i.e. so you need to pull the lever all the way up to get the shoes to engage with the drum.
If it holds the car
Possibly. But car doesn't have that much mileage about it 50k or is that about right
Take it along to your local garage for them to check and diagnose where the issue lies. With regards to the mot, if the hand brake is able to pass the tests on the rolling road but the lever is at the end of its travel, it will pass but they will add an advisory message.
