Have a arden blue corsa vxr owned it for a while 2011 50,000 miles always ran on b power fuel, last month fitted new delphi coil pack and plugs which fixed boost problem now when driving can hear bubbling in coolant tank and water is being ejected from the overflow tube on the side of the coolant tank iv fitted a pipe so it hits the floor directly as use the car to get to and from work iv also had a chemical test done on the hg and came back fine and no signs of oil or water contamination can visibly see how water and air being pushed back into the coolant tank through the top return hose causing the water to bubble up and shoot out of the tube I think this a problem with the thermostat and have ordered a cool running thermostat and gasket from Courtenay sport does anyone else think I have diagnosed this correctly and should fix the problem thanks in advance
