I changed the valve stem oil seals on my corsa and within 1 week my car has completely drained of oil and water just disappearing as well have I done something wrong, I pressed the seals onto the head and gave them a little chap to make sure they were correctly seated but when I put my head all back together the problems started it still smokes on startup, can someone please help me as I have head back off ready to put back on with new seals but I don't want to cause anymore damage
Hey Major, so say that you have lost all the oil in a week, seems extremely unusual. Can you give use a little back story again why are you replacing valve stems?
Also this forum is a great resource but only very few respond and what your describing is quite high end work. I would also consider joining the Vauxhall owners network forum, The Corsa forum and any others vauxhall specific I may have missed to widen your responses
It was reek as mad when I started it up in the morning so I changed all the head gasket set and timing chain set and replaced the tappets and lifters but then it started reeking again after a while and the oil was draining rapid so I took the head back off, I am waiting on new head gasket set tomorrow and I am going to do the valve stem seals again as when I finished there was a little spring where I was working from a valve seal unknown if it was new or old I put it all back together, the engine ran sweet except the reek again and the only thing I can think of was that little spring, thanx for the reply mate, maybe hoping you could help me a little bit if there's something I'm not doing correct TIA
I have been using fully synthetic 5w30 oil could that be a factor as well for an older engine
Some people have success changing over to 10W40 oil, but it sounds like you have excessive crankcase vacuum if it is devouring that much oil so quickly.
