This tutorial will show you how to lower your car by using photoshop.
It is best to start off with a side view of the car as it is much easier, but it is possible to do this on images from other angles.
First off we have the standard image:
Next you must select the Polygonal Lasso tool and select the area shown in this next image:
Once this is done, you will need to cut and paste so you have 2 seperate layers that look like this:
You then move the top layer so it is at the desired height, things may need a little bit of tweaking but this is essentially what ou car will look like once lowered! I find it is best to fill the top part of the bottom layer in black!
