1 - 10 of 10 Posts
Hi
I have a corsa d 1.4 design on a 09 plate
Can you have the computer fitted what tells you the m.p.g etc
Also are all the wiring there and is the read out by the trip computer/miles
Read out.
Also would you need new stick and clocks etc.
You want the GID screen pal, dead easy to fit. But if you want to use it with your standard CD player it will need to be tech 2'd to work
Anyone know if it is possible to have the larger screen fitted on the top of the dashboard to show the MPG and other menus?
thats what the GID is that is being referred to gregory. and then you would get a tech2 to actually have the information linked to the screen. One of Stempede's services I believe :)
So if i was to buy the larger GID screen and get it tech 2'd then it would show my MPG etc on the upper screen as i have an aftermarket double din stereo?
Discussion Starter · #10 ·
Sorry for being a bit thick to all this:hmmm: not had car long
do you have a picture of where these fit and what they look like
And do they connect to the stereo in someway
Cheers
1 - 10 of 10 Posts
