1 - 20 of 51 Posts
As you all have probably guessed I love SNOW FOAM!
Here's the deal you get 1 x lance with your chosen connector RRP £49.99 plus 1 x 500ml Super Snow Foam RRP £5.99 for £39.99 delivered!!!
We also have some add on deals for this
£17 extra would get you 5 litres of Magifoam
£32 extra would get you 10 litres of Magifoam
£12 extra would get you 5 litre of Super Snow Foam
£21 extra would get you 10 litres of Super Snow Foam
This is a great bargain and a truly great piece of kit.
We need 10 people to guarantee these prices.
Autobrite Direct were the first UK car wash supplier to introduce the SuperFoam. The original Super concentrated snow foam with a dilution rate of up to 200-1 with great cleaning ability. Autobrite SuperFoam has been specially formulated by Autobrite Direct. It is super a concentrated product and provides a thick mouse style foam to rapidly break down dirt. A super thick high foam,neutral cleaner containing a blend of detergents,wetting agents,foamers and sequestering agents for the removal of traffic film,grease,insects and dirt from all car & commercial vehicles.
Autobrite SuperFoam is a fantastic product which works great in conjunction with the Autobrite foam lance. It provides great cleaning action,excellent value for money and easy to use for that near touch less wash.The dilution rate is up to 200-1 so making this product very cost effective. Autobrite Super Snow Foam is used as a pre wash to loosen dirt and draw larger particles away from the surface of the paint, after dwelling for 5 -10 mins it leaves the car almost clean, in turn making the wash process easier and safer for your paint.
Directions For best results pre-wet vehicle surface and apply through a Autobrite Foam Lance via a high pressure washer. Dilute with up to 200 parts of water adjust the dilution for desired foaming. If using a Autobrite Foam Lance place up to 2 inches of the concentrate into the foam lance bottle supplied and then top up with warm water. Plug and play! When vehicle surface has been covered with a blanket of foam leave to dwell and rinse under pressure.
Key points of our product
Superior Cleaning Action
Very High Foaming Action
Excellent, safe cleaning action.
Contains no harsh chemicals.
Economical to use.
Produces blanket of foam on vehicle.
Contains biodegradable surfactants.
LSP Safe ( does not strip wax )
Leaves a Great Finish
Product Description
How To Use
Autobrite Heavy Duty Snow Foam Lance Probably the best Foaming Lance/Cannon on the market today!
The Autobrite Foaming Lance is now used throughout the world and now with many thousands of enthusiasts and professionals using them they really are the best and safest pre wash foaming tool to have in your collection! The Autobrite Foam Lance offers a very high level of foaming and delivers this through its high quality brass construction body and stainless steel injector which with its high foaming, durability and ease of use is certainly the most important key factors of the product.
The lance itself offers a wide range of connector fitments for your pressure washer 2 piece lance, such as the popular machines, like the Karcher, Nilfisk and Kranzle.
The Autobrite Foam Lance fits to the 2 piece pressure washer lance you have on your machine via a push and twist or screw fitments (depending on connector) giving you a secure, comfortable and stable hold on the lance when using it. There is a strong 1 litre bottle that attaches to the underside of the brass body of the lance, this holds 1 litre of either the Autobrite Magifoam or Super Snow Foam mix which gives you a thick mousse style foam that sits on the car for a period of time, giving you the safest and most effective way of encapsulating the dirt and grime into the foam, softening the soil in time and making it easy to remove when rinsing the car, leaving a cleaner and dirt free surface.
The benefits are excellent and really do reduce the risk of creating swirl marks, marring and fine scratches during the hand washing process. Every time you apply the Autobrite Foam Lance to your paintwork you will be taking a layer of dirt and grime from the car without touching it and with our Magifoam you can even create a near touchless wash for that totally safe wash! No more applying a sponge to the dirty panel of the car and rubbing the dirt into the paint, with The Autobrite Snow Foam Lance washing your car has never been so easy , safe and so much fun! Autobrite now supply a wide range of quality connectors for your pressure washer lance. With the likes of Karcher, Nilfisk, Bosch, Lavor, Challange, M22 Screw Thread, Nilfisk Quick Release and many more, we can, in most cases, supply you with the correct connector to fit your machine - ask for details! All of our connectors are made of quality brass construction with the exception of the Karcher K Series which are made from high quality and hard wearing plastic which in all gives you a nice and stable fitment.
The connector will be fitted to the lance via a stainless steel 40mm bar or a 20mm male nipple, which will give you an accurate fitment and will be secured with a non permanent thread lock for the extra tightness and "No Leak" fitting. The bottle that comes with our Autobrite Snow Foam Lance is made of quality HDPE that fits perfectly onto the underside body of the lance ensuring a tight and sturdy fitment when filled up with the Snow Foam or Magifoam mix. There is also a long plastic pick up tube inside the bottle which picks up the Snow Foam mixture when pressure is applied from the pressure washer machine. Adustments on the Autobrite Foam Snow Foam Lance could not be simpler. It has a black end nozzle where the foam exits from the lance and this can be rotated from left to right which will then alter the spray pattern of the foam when released from the lance from a pencil to a wide angle spray covering the car quickly and effectively.
There is also the black dial on top of the lance that alters the foam mixture from a weaker foam to a high thickness foam which is perfect for creating that perfect consistency of foam required when using our lance. Key Features as follows; New Heavy Duty Design, ideal for enthusiast or professional use. Quality design and fittings provide excellent durablility for everyday usage. Maximum Pressure up to 180 Bar. Max Temp 60 Degrees 1/4" Female inlet with 40MM Stainless Steel Extension Bar Variable, adjustable Spray Nozzle for accurate mixing and foam generation. Fully Adjustable dilution with setting dial. 1 litre container heavy duty bottle with our new style lable. Complete with your choice of connector (Karcher,Alto,Lavor,M22,Bosch and Karcher HDS Fix Fitting) All of our connectors are made of quality brass to ensure quality fitment and Karcher fitments are made of quality hard wearing plastic.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Discussion Starter · #2 ·
Updated first post to add in some extra deals for folks would want foam in larger quantities.
Dean
Banned
You keep quoting RRP which I think confuses it.
So its:
- 1 x lance with your chosen connector
- 1 x 500ml Super Snow Foam
for £39.99 (combined RRP £55.98)
Discussion Starter · #9 ·
So its:
Thanks for the comment this was done just to show what a saving there is here.
Your correct tho'
I have used this snow lance twice with the magifoam and its brilliant. Everybody should have one of these if you have a power washer.. Highly recommended x
Discussion Starter · #19 ·
Just had another 20 of these delivered if anyone is after a lance.
Already sold 15 lances since yesterday, we now only have 5 of these left in stock at this moment in time.
Don't worry we will have them in again as they're a regular item we stock however if your after one of these within the next few days/week we only have 5 available until we can place another order which could be in 2-4 weeks.
i have a professinal jet wash mate and has a gun lance like you see at your local car wash,now mine is a quick releace gun so i can swap lances,do you have a fittment to fit
1 - 20 of 51 Posts
