Hi,
My blower has stopped working completely on my 2012 Corsa d. Not on any setting. I have changed the motor and the resistor with no luck. All fuses are correct. I even started checking other fuses that might be linked. No luck. Now I don't really know what I'm doing with a multimeter but tried anyway to see if power was reaching the fan. It was telling me 2v not 12. Now I don't know what else to expect other than 12v and I also don't really know how to use one so this just might be a load of rubbish but is worth mentioning just in case.
Any help would be great.
My fan keeps sticking so i give the top of the dash a bang and it works on all speeds, i keep meaning to fix it but haven't got round to it yet.
This may help -
Easiest way to check is have the engine off, turn the ignition on and have the heater on 1, 2 or 3 then reach behind the glove box and give the wires a wiggle.
The air compressor likely at fault if no air whatsoever is coming through if everything else is working.
