Hi Richard, any update on your car regarding overheating issues, I hope you haven't given up and got your car scarpered.
I had very similar issues to yours, and replaced many things like new radiator, cleaned inner heater Matrix, new water pump, removed thermostat altogether to rule out stuck thermostat, replaced engine temperature sensor, replaced reservoir bottle caps 3 times, had my HG sniffer tested, all to no avail, and in the end no one suggested having Pressure Tested my coolant system, this is where the issue was, as engine heats up the water heats up just as it does in central heating boilers, its volume increases, this creates pressure in system, as well as some of the heated water will generate vapours, so if this pressure is used to help raise the boiling point of the coolant from the normal no pressure boiling temperature of 100c, to over 116c with a pressure build up of 10psi.
You can see what happens if there was no pressure being build or if your pressure was escaping, the engine coolant starts to boil at 100c or thereabouts and starts to spew out of the reservoir Bootle, emptying the engine of coolant, until such time as there is not enough coolant left surrounding the water pump impeller, so no further coolant gets pumped out to the radiator, or through the internal heater matrix, which stops giving out heat as there just isn't any coolant circulation, whilst the engine may continue to overheat, and fans kick in when engine temperature reaches 105c, but since most of the coolant has escaped, there is no more coolant flowing through the radiator and so it has nothing to cool even though your fan may be running at full speed, and your engine continues to overheat, this happened because your cooling system had no pressure as any pressure was escaping through something, and so when engine reached 100c most of the coolant had boiled out, hence the cause of overheating.
Finally I came here seeking help, and I was glad that members here were very helpful, my special thanks to SKI_1.2 who suggested looking into coolant Pressure, or any Leaks in the cooling system from where pressure might be leaking, so I went ahead and conducted a pressure test only to find that my pressure would not build up due to defects or manufacturing tolerances in the after market reservoir bottle caps, so finally I managed to trace the cause which was the inner O ring sealing to the bottle neck, ) ring seal was not making an air tight joint to the reservoir bottle, I guess over a long period of time, these plastic bottles can warp, or deform or necks wear out causing poor pressure seal, so I temporary wrapped a good few turns of white PTF plumbing tape around the cap bottom O ring seal, the smaller of the two seal rings, and this stopped my issue, now I have ordered a brand new bottle and its own cap, original GM part for just around £25.00, This will most certainly cure overheating issues when all else have been tried and failed. Pressure testing is the key to Euro 4 cars as they tend to run at higher engine temperatures, i.e. 105c, whereas my old school Calibra would run at around 85c to 95c where pressure is not significantly important, or critical, yes it is still pressurised but its fans cut in a lot earlier i,e at 85c hence keeping coolant to well under boiling point.
Water or coolant under pressure of 10psi will boil after reaching 116c so in Corsa fans cut in at 105, thus maintaining overall temperature to well under boiling point of 116c. I hope this will help.
