Hi,
The car is a 2011 1.0 12V Ecoflex 3 dr.
I've just got it back from my son and it's showing : -
- an oxygen sensor error code
- what do I need to know to make sure I get the right sensor so I can sort this out please? Also do I need to replace the lambda sensor at the same time?
- an occasional light on the dashboard saying my seat belt isnt plugged in - give the seat belt holder a wiggle and it goes away - where is the sensor for this and which bit do I need to replace to make it go away?
Thanks for your help.
Cheers,
Rod
The seatbelt connector sounds as if there’s a wiring issue somewhere as with you saying give it a wiggle and it goes away suggests that. With the o2 sensor give your reg to your local motor factors and they will get you sorted.
