Hi all,
I have read the above code via opcom, and done some reading regarding the issue.
This mainly being solved with a bit of WD40 on the waste gate for the turbo, now i'm willing to give this a go, but not 100% sure what i'm looking for or where in the engine bay I will locate it.
I begrudge taking this to a garage for what seems a simple fix.
Can anyone post pictures or a guide for what to look for.
1.3CTDI
Cheers.
Waste gate is quite common for seizing up on the 1.3 cdti, I'd start first by trying to move it manually by hand, it's a round unit about 1/3 of the size of the real small cans of coke, the 150ml cans. You can't miss the waste gate, look at the turbo and it's very close, withing 5 or 6 inch top of the turbo, it will have a thin rod connecting it to the turbo. You havnt said whether its the 75 or 90 bh 1.3's? If yours is showing 2034 code, the 90hp 1.3 has a variable vane turbo while the 75hp doesn't, if it's the 75hp I check the waste gate, while the 90 hp I'd be checking the variable vane turbo,, as well as the wastegate they do tend to over boost showing the po 2034 code.
I have a similar issue and am in the process of trying to remove the heat shield to gain access to the actuator rod. However, there is an an electrical connector that ForWeb1.jpg ForWeb1.jpg ForWeb2.jpg goes through the heat shield and I'm not sure what it is or how to remove it. Grateful for any help.
