here are the symptoms i found off vxro:
- When you lift the clutch up in 1st gear, while holding the gearstick, it will move back into you hand, sometimes 10-20mm!
- When Driving along in 5th and/or 6th, when you come on and off the throttle, the gearstick 'twitches'
compared to 3rd and 4th which will have nothing
- Whining in 1st, sometimes 2nd, 5th and/or 6th,
-Corsa's (Only) when turning right at 30mph+ you get a what is best described like a disc rubbing noise
so after doing some testing i have notices a disk rubbing noise when turning right, and when selecting certain gears the stick moves back into my hand (this is about 2mm) this happens in all gears apart from going from 3rd to 4th.
are these signs of the bearings wearing out? if so how long will they last? i have 3 months warranty and i hope to get it done by then if this is the case..
might just be me over thinking about it..
thanks
thanks
