Hi folks, anyone know much about swapping out a preface v grill to the facelift one? Straight swap or need a bit of tweaking? The dimensions look pretty much the same but I'm not sure how it will fit! Thanks :)
Given that Vauxhall list 2 different part numbers for pre and post facelift with the irmscher ones, I suspect it’d be a front bumper change to a facelift as I think the depth in the middle is different, it may just be the way pre facelifts look when debadged that makes them look that way, failing that a quick rummage through eBay on corsa d rebadged grill might give you a solid answer
Forum post on here (facelift grill on a pre-facelift ) seems to think it can be done but no solid answer
Discussion Starter #4
Yeah I've had a look on the forums but no one seems to know for sure! If I'm the first I'll have to let everyone know 🤣 thank you!
