Hi guys, I want to raise my engine on my corsa d (1.2) I am going to change the sump for a corsa b one as it is a lot shorter. I just would like to raise the engine so I have enough clearance to slam it and hide the wheel arch gap. Any ideas on how easy it is to do?
Rather than go to all that trouble, does the oil sump from the b fit a d engine in the first place, why not extend the arch lip down by 25 mm or so then once it’s down on air or coil overs you can make it look even lower that way, leaving you something to play with when it comes to speed bumps. Just the thoughts of a rambling old fart 😆
