I have a 2013 to lol. Would it be possible to use a third party steering wheel adaptor?yes yes i had an original T & C unit feat and controls on steer wheel worked! It's a 2013 Corsa D model
I've done some research and it seems you may need a separate adaptor for steering wheel controls in some cases.yes yes i had an original T & C unit feat and controls on steer wheel worked! It's a 2013 Corsa D model
@cheekytrucker had any luck?Ordered the relay, will let you know how it goes
ok thank you either case how can i be sure if my model is analogue steering wheel control or digital control?? becouse in one case i may need an adapter, on other case i only need to make some wiring connection....I've done some research and it seems you may need a separate adaptor for steering wheel controls in some cases.
This is listed in a post xtrons made on a forum
"it isn't just a given that any XTRONS unit you buy will work with your steering wheel controls, some vehicles require adapters.
How do I find the right CANbus TO WORK WITH SWC INTERFACE / ADAPTER?
We are not technically trained with all the various steering wheel control interfaces on different vehicles. Connects2 and other after-market accessories retailers developed universal CANbus boxes which can be programmed to work with digital SWC and other functions. However, we have very limited knowledge on this and you should contact your local professional car audio installer for help choosing the right adapter to work with your car and your new car stereo. They can also answer any questions you have about the installation and give you some ideas about the work involved. Please do ask to see proof or references that they do actually have the knowledge and experience to complete such a task."
The full post is here "XTRONS Head Units Steering Wheel Control Setup - http://bbs.xtrons.com/" and what supprised me is this is even though you have a can is unit I would have thought it should have worked without a separate unit.
Personally I have heard bad things about these connects2 units disconnecting after 30 days but not got much experience with using their stuff my self other than the fascias and cages.
They are digital as the use iso-resok thank you either case how can i be sure if my model is analogue steering wheel control or digital control?? becouse in one case i may need an adapter, on other case i only need to make some wiring connection....
I would guess you need something like this but I can't recommend what to get as haven't my self. Vauxhall Corsa D 2009 - 2014 On XTRONS Car Stereo Steering Wheel Interface Stalk 5055193343606 | eBayok thank you either case how can i be sure if my model is analogue steering wheel control or digital control?? becouse in one case i may need an adapter, on other case i only need to make some wiring connection....
I'm guessing you use it instead. I'd try post a separate thread in ice as I am only going by what I have read online.but in this case i have to use this adaptor AND the canbox sent with Xtrons?? both of them?
I could be wrong but judging by that post it seems to be the case. I would double check this with someone else just incase I have mis understoodthat's a very silly situation Xtrons should provide all material for this to work! i mean i have paid 250 € for radio and i'll have to pay almost 40 more to buy something that should already come in the box!
I know this is for a Corsa C but in theory you should be able to get a cheaper steering wheel control thing for a Sony stero or something and separate the wires like done here. Steering wheel controls for Erisin / Xtrons / Chinese stereothat's a very silly situation Xtrons should provide all material for this to work! i mean i have paid 250 € for radio and i'll have to pay almost 40 more to buy something that should already come in the box!
Have not forgot to come back with result. Purchased the relay from eBay, awaiting time to fit it... Currently on the back burner as I am fitting a kitchen, don't ask me why my wife thinks having a kitchen is more important than a reverse camera 🙄@cheekytrucker had any luck?
(I’ve skimmed through but assuming it’s an Opel/VX Xtrons Unit) The canbus box handles the steering controls too, you don’t need a Connects2 adapter for it. It should work out the box like all the other CANBUS features, but it might be something in the Factory Settings that isn’t allowing it to work.but in this case i have to use this adaptor AND the canbox sent with Xtrons?? both of them?
No canbus is how all the computers an systems communicate every car made in the last 30 years at least will have canbus.just a quick note is it possible that my model does not have canbus at all?
