Hi
I have a Corsa D 1.3 CDTI from 2006 its have a strange problem, i was in a carwash and run 200m then the battery lamp turns on and the RPM drops to idle (800RPM) and the lamp turn off again. But if i give it gas again its possible to run 1500-2000 RPM then its start again with the lamp.
I have try to connect VOXCOM to it and its dont give any errors, but if i use the read the RPM value from VOXCOM its drop to 0 when the battery lamp turns on.
Any idea whats wrong with it, i have look in the ECU and its looks fine and dry?
