Hey guys.
Have a Corsa D 1.2 sxi 2013.
I'm trying to figure out removal of the scuttle panel so I can see the wiper motor.
I'm expecting to see some screws for.removal but cannot see any? Surely it's not as simple as remove wiper blades and then pull panel off. Just don't want to break anything
Any help would be great.
It is that simple.
The scuttle panel clips into the bottom of the windscreen (there is a channel on the underside) and its just held in place under the bonnet by the rubber weather seal.
So it really is just a case of;
- take wipers off
- pull rubber seal off
- pull scuttle panel upward at the bottom to lift it over the wiper spindles then pull it out.
IIRC there is maybe some small pop fittings on the underside of but nothing you need to worry about.
