2011 corsa 1.3 Cdti eco flex .. I have not cabin heat .. fans all work changed thermostat now running to temp. Cleaned out matrix new fluids even changed bad expansion cap. Then I noticed it has coolant pipes going into secondary electric coolant pump .. has anyone had problems with this ? I brought new one still no pump does this come on only at temp or is it told to come.on via ECU? Help would be great
Sorry to jump in, do you know which relay/fuse this is run from by any chance? I need to pull mine out and have a look as the circuit is open, is the best access behind the glove box?
Hope you sorted your issue, mate!
What temps are you getting at the hidden temperature guage, have you purgued all the air from the system
