1 - 15 of 15 Posts
SECRET SETTINGS !!! ( I don't know if you know or not but hey I was excited!)
2008 onwards and will work on most Corsa's so have a try !
Access personal settings and preferences
Insert ignition key but don't turn it
Pull both indicator and wiper stalks towards you and hold it until a beep
This will bring you into the personal settings
There are 7 settings
You can select these by going up and down on the indicator stalk up and down
P1 - welcome Lights when you unlock the car
P2 - Auto rear wiper, when select reverse its comes on
P3 - 3 Flash indicator for passing on motorway etc
P4 - Automatic door and tailgate locking when you go above 10 miles an hour all doors lock
P5 - Selective locking, On for unlocking just the drivers door with one press of your key or off to unlock all doors with one press of your key.
P6 - Speed limiter warning - set the speed limit and will play a tone if you go over it.
P7 - indicator volume adjuster
To select an option use the wiper stalk to choose.
To save these setting that you have selected pull both stalks again for 3 seconds until the beep.
Now these are programmed to individual keys so you will have to do it for all keys.
Enjoy !!
:nevreness:
Hidden Menu 2
With the key in II position either engine running or not, press the trip button fast 4 times, on the 4th hold the button in till the display changes
Then you will be able to go through a list of menus by a single press of the trip button
1. date of fabrication
2. date and version of soft
3. ?
4. speedometer and RPM
5. battery
6.a) on bord lightining
b) engine temperature
7. ?
8.?
9.?
10.?
11. a) fuel left
b) Fuel level sensor readings??
12. a)
b) instant consm
13. a) number of days from last check
b) miles from last check
14. Trip and ODO
Programmed welcome lights, really cool. Was wanting my car to do that as noticed my mates VXR racing done it, as does my dads car.
cheers ;)
Enjoy !!
:nevreness:
Some reason It won’t work I don’t turn key n hold both window wipers n beam towards me nothing happens any idea
Hidden Menu 2
3. ?
5. battery
7. ?
8.?
9.?
10.?
11. a) fuel left
12. a)
b) instant consm
14. Trip and ODO
cheers for this bud I have been trying for a year to get my central locking to work with one press 👌👍
1 - 15 of 15 Posts
