Hi I have recently picked up a 2013 sri 3door, and I'm after changing the cable in the seat that lifts up to pull the seat forward to allow passengers in the back. At the moment it won't go back unless I spend some time fiddling with the handle, and therefore believe the cable has stretched over time. Any advise and which part to buy to replace
Cheers
Dean
Got the same issue, there's 2/3 wires that run from the handle to each side of the seat, for me 1 of the wires broke so as a temp fix I just pulled the wire out so I can manually pull it along with the hanlde, but I guess I'm planning to fix mine soon too.
You'll have to find the wires, here's a set, it's out of stock but gives you an idea of what you're looking for: Vauxhall Corsa D Front Seat Tilt Release Cable, Handle & Bar - Drivers or Passengers - Corsa King
