1 - 8 of 8 Posts
I’ve recently just had the car in two garages, first garage thought that timing chain needed replacing so I took it into another garage that could do that. They came back and said the timing was fine however the car was having difficulty in turning over which was the reason I had the car in the garage in the first place. Anyways got the car back from that garage still not always starting, and stalling when you left it running for longer than 5 mins.
Went about replacing the crank sensor which done something however car still wasn’t always starting. I then realised that what was causing the issue was the coil pack. Changed it yesterday and everything has been fine up until today, had yellow engine management light come up, again only for code p0014 camshaft position “b” sensor however their is now a loud rattling / tapping coming from the engine that gets louder the further you put your foot on the throttle. I’m thinking seen as apparently the timing chain is fine it must be hydraulic lifters? Any other ideas. For a corsa Sri 1.4l 16v 10 plate model.
Probably best getting it into a specialist lad could be numerous things could be a simple wiring fault im also going through same situation car is in vauxhall as we speak
Hi mate, car needed a new engine. Was the bottom end, would have been more expensive to rebuild Hope this helps. All in costed me about £700
Sorry to hear this happened, thinking about it, I was thinking maybe failed oil pump, butyou have it sorted now, how has the new 2nd hand engine getting on for you?
1 - 8 of 8 Posts
