Tonight temp light came on. I checked under the bonnet and got as far as this.
Heater on hot but only cold air, rad expansion bottle not lost any water, the bottom hose on the tank is hot, pipe coming from the distribution housing on the right side hot at rear, the pipe going into the bulkhead hot, and pipe coming out cold. Does this sound like an air lock or possibly water pump or Thermostat stuck??
Should water be coming back through this pipe when running? If it isn't would a stuck thermostat prevent it?
