Had an intermittent fault a few weeks ago with Throttle Position Sensor 1-2 Implausible. Originally I thought it was down to the accelerator pedal sensor so I’ve swapped the whole pedal out which was fine for a few trips.
Had an emergency journey of 200 miles to Scotland and it looks like the issue was still there. Over the 200 mile trip I had to clear the fault 3 times otherwise it’d be stuck in limp.
I’m guessing it’s down to the other sensor, is that within the throttle body? So therefore a whole throttle body change?
I use cruise control on motorways and it seemed to trigger limp mode even while there was no pedal usage which I’m guessing means the pedal is fine?
