1 - 1 of 1 Posts
Here's another easy mod to do: Tinting windows on a car!
Firstly, open up the picture of the car which you want to mod, in this case, I've chosen a new 3 series:
Nextly, you need to select the window/s you wish to tint. In this case, I'll just do the back windows. I find it easiest to zoom in, and then use the magic brush, and then select it all, and then de-select the bits I don't want to tint.
You can also use the lasso, depends on what you're more comfortable with!
Once you have your window/s selected, go into Image > Adjustments > Brightness/Contrast, then select how dark you want the window/s, and then press OK. You can always go back into the Brightness selection again, and make it even darked, if you wish.
Once you're happy with how dark you've got the window, all that's left is to save the image, and admire your handy work!
1 - 1 of 1 Posts
