1 - 1 of 1 Posts
Hi
I have fitted an IPC with the larger display & a new wiper stalk that you twist to change the menu on the IPC, I have paired the IPC with BCU with my tech 2, but I am still showing a DTC code B3750 "Board Computer Switch Circuit Open", I can only presume that there is a "missing wire" like on the cruise control, the question is if I am missing the wire then would you know the pin numbers for the connectors for the wire to connect from the CIM to the BCU or if not then could rectify the fault for me.
Regards
Mark
1 - 1 of 1 Posts
