This is a tutorial for how to fit the Armster Armrest: http://www.irmscher-bits.com/catalog/product_info.php?products_id=493
This mod took about 5 minutes to install. Not even that, really! To make things easy for yourself, I'd recommend pulling out the cup holder from the car to work on. It's clips out very easily, if you just pull.
When you have the cup holder, put the bottom part onto the cup holder, and mark out where the four holes should go, then drill them.
Once the holes have been drilled, take the bottom base, and attatch it to the top base using the longest screws you were given.
Once that's been done, take the armrest, and the cup holder, and put them both together, and use the smaller screws you were given to screw them together using the holes you just drilled.
There you go, all done. Now all's needed is to attatch it back into the car. To do this, use the back end of it, and clip that in first, and then clip the front in, and hey presto, you've got a nice new, comfy mod. Enjoy!
