1 - 1 of 1 Posts
1. Open bonnet and remove pannel under the windscreen (air con compartment) It has two torx which are T20 (size) in the middle, the top part then clips off.
2. You will see in the top left hand corner a load of wires going into a rubber ring going into the car, cut a hole in this and push about 2feet of the red cable into this.
3. Remove glovebox with 4 more torx T20 again and you will see the red cable again in the top left corner.
4. Pull the cable through and place through the car to the amp into the 12+ input.
5. Get the blue cable and connect this to the blue cable on the back of the stereo, then run it though the car to the amp and put it into the REM. Input.
6. Get your phono leads (like speaker cables but the ends are like earphones. one red and the other white) and plug these into the rear of your stereo, then place down your car into the phono sockets labeled INPUT.
7. Find your earth cable (black one) and connect it to GND- or EARTH on the amplifier. then take off one of the panels on the side of the inside of your boot ( these are on clips so just pull them) and you will see 2 white bolts, undo one of these and put the black cable on it, then tighten it back up.
8. Connect your speaker cables to amp and then to sub making sure the positive goes to positive and your negative goes to negative.
9. where you have the red cable left under the bonnet, connect it to the positive of your battery, this may spark slightly but do not worry it should not be dangerous.
10. Hide cables throughout the car and get ready to listen to some bass :)
Hope this helps.
1 - 1 of 1 Posts
