1 - 1 of 1 Posts
This is another very simple modification to do.
Above the driver's side door, there should be either a handle, or two covers where the handle should go, either way, you need to take these off.
To remove the covers, just pop a screwdriver underneath, and prise it off.
To remove the handle, you need to pull back the little cover, and remove the screws from either side of it, and then it should just pull off.
Then all that's left for you to do is to push the sunglasses holder into place, and you're sorted.
1 - 1 of 1 Posts
