As the vectra b v6 is a 5 x 110 and the corsa a 4 x 100 so not without drilling new holes in the disc unless you’re on a vxr or a 1.7 then they’ll go on but given the v6 disc will be smaller then the vxr one then why not just go to vxr spec brakes
I can get them free and was going to convert it to 5 stud for more wheel options not really worried about stopping power just wheel options
Suppose ultimately the wheel hub to bearing to upright sizes are going to be the things to check, given the corsa d astra h and vectra b do share quite a few oily bits I’d imagine they do swap over, be interesting to see what comes up
Can’t see the 5 stud on the corsa 1.7 & vxr being much different from the astra h cdti & vxr or the vectra b as it’d cost too much to produce separate hubs for different models
