The indicators on my 57 plate corsa d are flashing faster than they should, just need to know where the relay for the indicators is.
Have you got any led bulbs installed or are any bulbs out?
As far as I know the flashing is controlled without the use of a relay as I can't find any mention of one in the fuse diagrams. More than likely the relay will be built into the BCM or ECU and will not be used serviceable if it does have one.
