I have Vauxhall Corsa 1.7 CDTI showing p0409 code egr sensor circuit a fault just wanted to know if anyone has had
any experience of this fault. The car feels slow to drive and not very responsive and will rev to the red line when cold
but after 3 mins of driving will go into limp mode will not rev past 2700 rpm.
any advice would be greatly appreciated.
Work done already to the car as car was bought from auction had a problem when we bought it
was boost sensor fault
boost switch fitted cost ÂŁ300
which improved slightly
then the next fault
Turbocharger low boost fault
new turbo fitted from turbo pacs
and egr cleaned cost ÂŁ1400
and this made it worse as it used to rev to 3500 rpm before hitting limp mode and now is showing the above fault
then the next fault
