Hi all,
I brought my daughter an old 2010 corsa to learn to drive in, but it seems to be misfiring on cold. Runs fine once warmed up a bit but I can smell the mix is completely off.
I ran a check on maf / rpm from idle to 3k (see attached). Does it look right? That peak before flatting at 1500 rpm looks wrong? Plus that seems quite rich at 800 rpm idle?
also can anyone tell me what the pipe in the yellow circle is called? It’s covered in oil so I’m guessing it’s leaking but none of the cdtis I see online have one of those pipes! It’s a z13dtj engine if that helps. Thanks
